Guest Simon Posted June 19, 2003 Share Posted June 19, 2003 Need Info!! here is some pictures of my VG30DET http://www.wn.com.au/simona/pictures.html Need some help with what I think is the variable valve timing, There are some pictures of a solenoid or something connecting to the intake cam at the back of the motor (one on each head) I do not know what it is And how does the VVT work How do you run it Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted June 20, 2003 Share Posted June 20, 2003 im having a guess here: the VVT is controlled by the solenoid at the end or the cam which pushes in a valve. The valve allows oil pressure to cam gear and rotates the cam, Its just a guess.. Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted June 20, 2003 Share Posted June 20, 2003 Valve Timing Control (VTC) Solenoid Valve One valves is installed on one cylinder head (two valves total). This valve takes a signal from the ECM and controls oil pressure to the VTC sprockets. This then regulates the position of the intake camshafts. just somthing i found - its on a VE30DE, similar to the VG30DE Quote Link to comment Share on other sites More sharing options...
