Guest shuyun Posted June 23, 2003 Share Posted June 23, 2003 I am buying a 1981 280zx Turbo. It is a Long block donor I plan to uses its stock L28et into my 240z as a L28T with a draw through turbo. See my personal Folder for pictures of the turbo setup. What do I need to get to make the engine run properly? I am looking to get the proper MSD type Ignition box for boost retard and knock sensing. But what need to be done to the distributor? The car has a Volt Coil on the inner finder do I need to make sure it is compatible with the box /distributor? And if I have not asked the proper questions and you feel I need some more Info let me know I start with the mechanical swap Saturday. Thanks for you help. Quote Link to comment Share on other sites More sharing options...
