Guest Nic-Rebel450CA Posted June 26, 2003 Share Posted June 26, 2003 well, i'm pickin up my first Z The only problem it has is that the breather lines for the fuel tank etc leak fumes. The guy said that there is a pretty easy-to-follow procedure for eliminating the need for these lines and that part of the system (as I figured there would be). Does anyone here know this procedure? (If not I am sure I will be doing a writeup of my own procedure within the next couple weeks) Car: 1970 240Z Quote Link to comment Share on other sites More sharing options...
Guest rick458 Posted August 6, 2003 Share Posted August 6, 2003 I replaced all of mine last week when I redid my tank took a lot of hose and a fair amount of time Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted August 6, 2003 Share Posted August 6, 2003 http://www.mcmaster.com sell the fuel hoses in the proper diameters to replace them. As for getting rid of some of them, I would think the only ones you need is the one on the very top of the tank to the vent tank, and the one that Makes a "U" from the filler hose to the vent tank. I would pinch the others shut and weld them up for 100% seal. Someone else here on this board got rid of all the vent lines except for one. Maybe he'll put his $.02 in on how it worked out and if there are any unwanted side affects of getting rid of the extra vents. Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted August 6, 2003 Share Posted August 6, 2003 I was thinking it might be possible to remove all of the lines and the vapor bottle and place a breather cap on the filler neck instead. (of course, I found that there is one line that goes from near the top of the tank to the filler neck to let air out of the tank while the tank is being filled so that one would need to stay unless I can teach my gas tank how to burp) Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted August 6, 2003 Share Posted August 6, 2003 The gas tank burp is why I would keep the one line on the top of the tank and the one on the filler hose. I could be wrong, but if you keep these 2 you shouldnt have any problems with filling her up. Quote Link to comment Share on other sites More sharing options...
