How much weight can i expect?
Guest 280Tom'z
Guest 280Tom'z
Hey my people i'm new to this fourm mainly because all the names i could think of were gone. but i have a pretty extensive knowlage about cars so if you have questions i'll be glad to help. but i was wondering how much weight will a 350(383) and a T-56 add to my 76' 280. because i'm going to cut the springs (not enough $$$ for coilovers) and i need to know the weight to put in my car so it will sit right when i'm done i want a lower fatter look. great to be here and thanks! weird.gif
Guest Fast Frog
I've got a 383 in my 76 280Z. If you lose the heavy ugly bumpers and brackets, use alloy whls, alum hds and manifold and carry no spare tire or jack; you should weigh in at around 2650lbs curb wt like mine. With alum water pump and alum radiator, another 20lbs or so less. However, since you're going to use a T-56, add back 40lbs or so. I use a WC-T5 which is smaller and lighter!
