Got some questions...need some answers :P
Jwink25
Got a couple of questions for you guys...
I have a 240Z with a 1982 turbo 2.8L engine.
1. If I remove the EGR valve and cap off the holes, will it make the car run bad? I will be using the stock ECU for a little while. Others have done this I am sure, I just want to be sure.
2. If I upgrade to a 240SX or the Big Throat TB, will the stock ECU run the car ok as well? I think I will need to adjust the airflow meter, right?
Plus, I'll be running more boost, a TO4B, 3 inch DP, and other minor upgrades.
Thanks,
Jason
Guest 240hybrid
Question #2.....Im pretty sure that you just have to readjust/reprogram the throttle postion sensor (little black box on side of TB). Get a haynes rebuild manual and it should give all the instructions on how to do this. I know that the service manuals will tell you if the haynes doesnt. This doesnt take long at all.
Chase
