turbo specs question
Guest hgray14
Guest hgray14
I saw this turbo for sale and am wondering what it means exactly. I have turbo books but I am looking for a quick and dirty answer on the stats of this turbo.
I know that 3" in and 2" out is good. My question is on the SPECS. I am going to be running an '82 turbo Z engine with NPR intercooler and improved fuel delivery, maybe even double injectors for each cylinder. If I can fit NO2 in there somewhere I might do that too. I am always struggling between whether I want my power from the starting line or whether I want a lot of high end power because I like to smoke people off the line but I also like to drive over 130mph. Anyway, what does .67 wheel trim, .70 A/R compressor and .63 A/R turbine tell me? Will this turbo be better for high end or low end power? Does this tell me whether it has a wide or narrow power band? Can a turbo like this really do 28 psi? That seems really high.
any help you can give me will be greatly appreciated.
Houston
TURBO INFO:
3" INLET DIAMETER
2" OUTLET
WET FLOATING BALL BEARINGS
1/8 NPT OIL INLET
T3 / T4 FOOTPRINT OK !!
SPECS:
.67 COMPRESSOR WHEEL TRIM
.70 A/R COMPRESSOR
.63 A/R TURBINE
THIS TURBO CAN EASILY DO 28 psi
610 whp ON B SERIES SWAPS
Standard T3 Flange,
Perfect for any 4-6 cylinder.
Mitsubishi Eclipse, Honda Civic, Prelude, Integra, Ford 2.3L Turbo Etc
