Ok, another LT1 question, 4l60E and VSS
Guest Craig280z
Guest Craig280z
I have been looking at the JTR manual and I'm not exactly sure why they have you move the VSS to the
govenor area on the transmission housing.
I am assuming that the 4L60E uses the VSS for computer information and also the speedometer and that
my 78 280z will need a speedometer cable added and it would be added where the VSS originally
was installed.
Is this correct? Is this the way that it is normally done or can you get a speedometer that will take the signal
from the computer?
You guys are going to get tired of my questions because I have a bunch of them. I'm trying to spread them
Thanks a bunch!
Craig
Guest Craig280z
Hi Mark,
Thanks for the reply.
Am I correct in my assumption that the LT1 does not use the speedo cable for the speedo which is why JTR is having me relocate the VSS so I have a place to mount a speedo cable and a reason to buy their $90 reluctor ring? smile.gif
Thanks
Craig
