intake help... (making a tech guide)
Guest thebarracuda
Guest thebarracuda
ok. I've started compiling some tech listings of junkyard parts for the Z.
I'm starting on the intake. So far I have:
60mm TB (needs spacer and linkage adapter) increases throttle responce
allows
from 19?? 240sx
what year/s does this mod work with?
also, is there any other make/model with a bigger (than 50mm) TB that will fit with relative ease on certain/any model Zs?
I dont mind reading a bit if you have a link. (I have sarched, and still am searching)
thanks in advance I'll keep you posted.
Guest jt240z
The 60mm throttle body will fit any L series fuel injected engine from 1975 to 1983.
The 60mm TB can be found on any KA24 engine used in the 240SX and some Stanzas. I'm not sure about the years.
The 300ZX had a 55mm throttle body that can be used on the early fuel injected Z's as well. The modifications are similar for this TB.
