Trans for L6 3.1L
Guest billyzbear
Guest billyzbear
I've got a 240Z with a 3.1L roughly 300hp motor. I keep brakeing the trans. I have been using 280ZX 5spds. Is there a good trans that will bolt up that can handle the beating? HELP.
Guest billyzbear
After going through some old posts, I see a good replacement would be a 81-83 turbo 5spd which is a T5. From my understanding, It will bolt right up. What about the shifter and drive shaft? I have 300ZX lemited slip rear end and this is in a 71'. Also, is the differents between a Ford & Chevy T5 the input shaft, bell housing and rear output shaft?
