casting number help...
Guest butlersZ
Guest butlersZ
Hi,
I have aquired a 283 block with the casting number 3959532. Can anyone tell me about this block such as when it was made. I plan to bore it to a 302 and put it in one of my Z's. Also, it has the "dip" in the bottom of the cylinder walls instead of the flat bottom, in case that helps with the years it was made. Correct me if I am wrong, but doesn't that signify that the block was made using the 327 tooling? There is another # on the block, CEOB00773, what does it mean?
