Guest Big Phil Posted May 13, 2002 Share Posted May 13, 2002 I have a 95 Camaro LT1 and I finally found a company that manufactures a reasonable priced bracket to delete the Power steering pump and A/C compressor. There are a few other companies that make brackets but they charge way too much ($400) and they required you to purchase a corvette harmonic balancer ($400). A shop in Houston,TX sell a complete kit for $175.00 and it includes includes everything you need. The company is called Mad Man Racing. It is a low mount bracket alternator bracket and it should clear the frame rails. Phil Mad Man Racing Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 14, 2002 Share Posted May 14, 2002 Low mount brackets sometimes have a problem with the JTR setback plates contacting the back of th e alternator (or whatever accessory you have down there). If the LT1 uses them which I believe it does, double check your clearance before committing to that setup. Just a word of potential interference I believe BLKMGK had a problem with that and finally went high and on the passenger side (older smallblock and not a LT1 though, so no serpentine belt). Regards, Lone Quote Link to comment Share on other sites More sharing options...
VRJoe Posted May 14, 2002 Share Posted May 14, 2002 I have a '94 LT1 from a Z28 and right now I'm looking into using the A/C bracket from a 92-95 Corvette. This way the Alt. can stay where it is (high passenger side), the A/C can be moved to high drivers side. I'll keep everybody updated if it works. I'm going to get some measurements from a 'Vette setup this week, then I'll know. The bracket was around $70 from a dealer. -VRJoe Quote Link to comment Share on other sites More sharing options...
Guest LT-1 350Z Posted May 15, 2002 Share Posted May 15, 2002 I have the corvette lt 1 motor with the original bracket.altenator fit perfect but no clearance for the a/c comp (i remove my a/c system to make my car lighter)good luck with your swap i love the way the lt 1 drive on a 2600 pounds Z. Quote Link to comment Share on other sites More sharing options...
