Guest Bob L Posted July 23, 2003 Share Posted July 23, 2003 Hi Guys, I'm looking to find the height of a Holley double pumper carb (say a 750) as measured from the carb pad to the air cleaner ring. Does someone have this measurement? I'm in the middle of some hood clearance arithmetic. Any thoughts as to a practical minimum for hood clearance with solid motor mounts? 3/8"? Thanks for the help! Best, Bob Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted July 23, 2003 Share Posted July 23, 2003 If there are no replies I can go check when it's light out. Mine is a 650; I don't think there should be any difference. Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted July 23, 2003 Share Posted July 23, 2003 I am at work but if no one replies by the time I get home I will go measure my Holley 750 dp for you. Mike Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted July 23, 2003 Share Posted July 23, 2003 Mine measures out to 3 and 3/16" ; it's 3 and 1/4" with the air filter gasket in place. There shouldn't be any difference between the 650 and the 750... they fit the same float bowls, I believe.. unless the center section needs to be taller for bigger venturi or something. Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted July 23, 2003 Share Posted July 23, 2003 I just measure my Holley 750 dp and I have 3 3/8" from the bottom of the base to the top of the lip of the aircleaner base lip. Hope that helps. Take an 1/8th of an inch off if you don't include the lip. Mike Quote Link to comment Share on other sites More sharing options...
Guest Bob L Posted July 24, 2003 Share Posted July 24, 2003 Exactly the information I was looking for. I also just found out that a 4v throttle body (Lingenfelter 2000cfm) is 2 3/8" tall when similarly measured. I very much appreciate the help. Best, Bob Quote Link to comment Share on other sites More sharing options...
