Question about TWM 60mm TB
74Adam
I was talking to Steve Ehlers at Rising Sun Performance in Ft. Worth about bigger throttle bodies. He is basically of the opinion that the TWM TB is inferior to the Webber TB that it is a copy of (and no longer available). According to him, the TWM copy "sticks" off of idle. For those who don't know, Steve is a real perfectionist ("if it isn't done perfect, it's wrong"). A good quality for someone working on your car, but when giving advice can lead to unrealistic expectations. Anyway, for those that use the TWM, are you satisfied with it? Any problems? I would like to retain the stock linkage, so this is really my only alternative (that I know of).
thanks,
-Adam
Guest gerryG
I too have a TWM -- ABSOLUTELY no problems. I am very picky about the idle since my car is a "weekend" driver.
During setup there was a small problem due to the size of the 60 mm TB -- by re-adjustment of the TPS everything was sorted out.
I bought both the TWM and a 240SX TB -- the TWM is much more saniatary so I put it on the car -- have 240SX unit left over.
go for the TWM...
gerryG
