Key less entry kit HELP!
Guest sukow2001
Guest sukow2001
ok I got a key less entry kit(because the keys don't work on locks) from victoria british and the directions SUCK!!! But I have pretty mich figured it out. I was wondering where I can hook it up for power (12volts)?
Where can I hook it up to a gound?
Please help
I'm not sure how much power you need for your solonoids, it is probably a fair bit. I would run a line right to the starter for posative, and a decent line to the chassis for ground. If you could find out how much power these units draw that would be a big help... but I'd suggest 12ga wire just to be on the safe side.
