Guest racingfanscjww Posted July 29, 2003 Share Posted July 29, 2003 Well I have been bit by the V8-280ZX bug, first off I'm new to this scene but not to mechanic work. I have a question, OK here is the deal I'm installing a new timing chain in a guys 260Z in exchange for a 78 280Z, it has a very good body and I'm going to drop in a 350, can I get some advice on the timing chain install here on this forum or where can I go? The 260 is stock. Thanks, Chris........... Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted July 29, 2003 Share Posted July 29, 2003 First off, welcome! You need to post in the right forum, "L6" to get the correct info. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 29, 2003 Share Posted July 29, 2003 I think the haynes manual has some good info on that. I don't think there are any special tricks to that procedure. Just taking time and following the manual to the letter. I will tell you this. Don't take any more bolts than you have to off that front cover. There are a bunch around the perimeter that hold the front cover to the block and then 2 that go through the water pump and into the block. It's a really good time to change the water pump. It would take you an additional 10 min and maybe the guy will pitch in a case of brew. Your gonna need it after changing the timing chain in the car. Quote Link to comment Share on other sites More sharing options...
