Turn Signal Problems 260 Z
Hi; Guys Finally Took My Z for Its First Ride Today. Everything Seems to work But Turn Signal Work Untill I put On The Lights Than They Dont Work At all...One Side Works If You Put On The Flashers.... I have A late 74 260 With A 76 wiring Harness..... Any Help Would be Great....
Thanks Jim
P.s. It Was A Awesome Ride .... Soon ill post some pics
Guest Al 260Z
76 harness in 74 ??
Sounds like a headache. You'll need FSMs for both years to really figure out what is what.
Do the obvious: Check for blown fuse. Look for disconnected connector on steering column or under dash in passenger footwell (I think that's wher flasher relay is). I've labelled most of the relays with magic marker as I've worked on mine. It's pretty confusing even with FSM and decent sized diagrams. It's a nightmare without. FSM has long section with item-by-item diagrams for most electrical circuits. Beats trying to trace wires in reduced size diagram in Hayes.
Good luck,
Al
Thanks Guys For All Your Output.... It Ended Up Being A Short In Front
Turn signal Left Side
Thanks Again
P 8) .S. Keep The Sunny Side Up.... 8) Jim
Guest rick458
I now have Headlights, interior lights, hazard lights, and parking lights,
highbeams /lowbeams work, license plate light works, but NO turnsignals.
I did notice I have a front side marker light out on drivers side, and no activity in the blinker relay. I will replace the bulb and the relay tomorrow
and see what happens
