Guest Vashe Posted September 2, 2003 Share Posted September 2, 2003 Whoa, almost posted in the Chevy forum, but remembed this was here:-p My question is on a ZX 2+2 car, is there a certain length or angle that i should watch out for when install a mild 350 and T56? thanks in advance for any input guys:) Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted September 2, 2003 Share Posted September 2, 2003 For the length, you are going to have to measure it specifically for your car. You local drivetrain shop can tell you how, because they will be building your driveshaft anyway. For the angle. Try to get as close to straight as possible. There is lots to understand about driveshaft angls and how they cause vibration. The most important concept to understand is that the output shaft of the transmission and the pinion gear centerline need to be parallel to each other, but not necessairly co-planar. See this site for more explaination: http://drivetrain.com/driveline_angle_problem.html The reality is, in constructing home-brew hybrid vehicles, the theoretical sometimes takes a back seat to what is possible. A cool little tool I just saw is here at the bottom of the page: http://www.compcams.com/catalog/349.html . It can measure driveshaft angles pretty easily which is the most difficult part of setting up a drivetrain. Quote Link to comment Share on other sites More sharing options...
