air-fuel ratio regulator
Guest Nic-Rebel450CA
Would anyone buy this or does one already exist?
I was thinking of making a regulator for FI that would control the air-fuel ratio. I was thinking that I could basically make a circuit that would go in-line with the O2 sensor and modify the O2 reading to make the system react differently to the reading. To richen the mixture it would tell the system that the O2 sensor is basically getting a lean condition, and to create a lean mixture it would tell the system that it is running rich.
I dont know enough about FI to tell if there would be an easier way to regulate air-fuel ratio on-the-fly, but I may find such a solution in my learnings, and I would also be open to suggestion.
(All I can find is something like this http://aie.safeshopper.com/156/3248.htm?559 that is over $300)
