13.519 @ 106.49, NA L6
Dan Baldwin
That was my first ever run down the drag strip! Not too shabby, equalled Norm's best trap speed (way slower than his quickest ET)! I went with a friend from my time-trialling club. He's never beaten me on the road courses we go to (has been within a tenth, though) in his 260fwhp 2240 lb. Omni GLH-S. I think he figured to beat me at the drags. I won the first two rounds, but my trap speed was dropping as I was having fuel pressure issues, and he beat me on the 3rd and 4th runs (I still had a quicker ET on the 3rd run, SUCK reaction time, though). His best ET was 13.888 @ 107.56, best trap speed was 108.77 (14.097). Needless to say, he was having trouble hooking up:)
thats really cool, congratulations. I went to shelby weekend at infineon and watched all the mustangs drag race and that was awesome but you ran faster than a lot of them. I wish I could have an engine set up like yours. BTW how high can one of those things rev. Do you lose revs for stroke? That would be cool if i could hit 7.5 grand with a stroker
General rule regarding strokers is that you lose revs with the square root of stroke. i.e., if you increase stroke 10%, your rev limit should go down on the order of the square root of (1/1.1). So, theoretically, your redline would be reduced by a factor of 0.95. So you've gained 10% more torque EVERYWHERE, and only lost 5% of your rev potential.
Specifically regarding the L6 stroker, I limit mine to 7000 rpm. I am assured by a source at Nissan Motorsports that the 240SX pistons I'm using are regularly revved to 7500 in KA motors, which has a much longer stroke than a stroker L6. So they should be good for more than 7500 in a stroker L6. I'm also told that the stock L24 rods are good for 7500rpm in a stroker. I do not know what revs the forged diesel crank is good for, but I'm sure a properly prepared one could be made good for 7500.
I have made a 7200 rpm "pill" for the MSD, but I'm not planning on using it anytime soon. I think I'm being fairly conservative at 7000, I don't really feel the need to push it beyond that at the moment.
setup in brief:
N42 bored and stroked to 3.1 liters
N42 head ported and cammed (.550"/~305deg) by Sunbelt in Atlanta
11:1 CR, 93 octane pump fuel
3x2 45mm OER Racing carbs, 38 or 39mm venturis
'84 truck 5-spd (3.321/1.902/1.308/1.0/0.833)
3.70 R200 LSD ('87 turbo)
showphoto.php?photo=6881&size=big&password=&sort=7&thecat=500
dyno plot here if the image doesn't show up: http://www.classiczcars.com/photopost/showphoto.php?photo=6881&size=big&password=&sort=7&thecat=500
breakup above 6000 due to being forced to use points temporarily
