Guest 350zgto Posted September 20, 2003 Share Posted September 20, 2003 Info that may help others. I am doing a 240 JTR swap. I have D-port angle plug heads. I got a set of Patriot #8019. The ports are poorly shaped, they do not conform to the D-shape, although they do "pull in" toward the block considerably, to help clear the steering shaft. Foreseeing sealing issues at the ports, I sent them back. I got the Sandersons, 1.625 with a 3" Collector and are shorter vertically, D-port flange is beautiful fit, but I don't think they will clear the steering shaft due to larger collector, double flanged collector, and shorter vertically. (Instead of collector being below the steering shaft, it might be right in the steering shaft. Anyone have experice with this header or know of another to fit D-ports angle plugs that fit? Quote Link to comment Share on other sites More sharing options...
