engine power fade??????
i have a 76 280z that i have done the turbo conversion to , after getting everything put together, adjusting the timing and doing a valve job it revs great up to 5k then power fades drasticly,, i have a costum fuel system so it might be fuel supply,,, havent checked that yet. maybe fuel pump problem??? if so what pump do you recomend??? any other ideas?????
Guest 72datsun240z
i don't know that much about turbos but i do think that you will need more fuel coming in to the motor to run the turbo . what you need is the electric pump like they have in Motorsport auto .
