Light problem
Guest jeff1216
Guest jeff1216
1st.............all fuses are good
all bulb are good
all lights work except..............................
Bright lights (head lights)....dim are fine
Brake lights dont work
only the speedo and a/c light work....rest are black
Where do I start?
Hazard light switch for the running lights and high/low head light switch for the head lights. Cleaning the hazard light switch is cake. If your real careful you can clean the high/low switch, or just replace it. Real easy to break the plate the contacts are on, especially putting it back in. I just went through this process on my '77 just this last week. Had no problems fixing my '74.
