Guest Z-rific Posted October 2, 2003 Share Posted October 2, 2003 I'm posting here because the "Fuel Delivery" forum looks to be mostly L6 fuel system info. I just added a fuel pressure guage in front of my Q-jet and it's reading 8 psi. I know this is a little high, as I believe Q-jets work fine with 3 to 6 psi. But is it too high? Should I add a regulator in and drop it down to 5 or 6? Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted October 2, 2003 Share Posted October 2, 2003 I have not owned a Q-Jet in awhile but it seemed to me 6-7 lbs was max. I could be wrong, I am more familiar with Holley and they are good to 7 lbs after that it can be iffy. Mike Quote Link to comment Share on other sites More sharing options...
Guest zbot43 Posted October 3, 2003 Share Posted October 3, 2003 I would recommend putting the fuel pressure regulator in, and setting it for no more than 6psi. You should be able to get away with 6 psi though. If this is in a Z and not an offroad vehicle that should do just fine. The needle and seat set up can't handle much more than that, and offroad forget about it. Quote Link to comment Share on other sites More sharing options...
