Turbo swap into a 260z ignition help
I`m just finishing the swap from a 81 zxt. My ecu seem to receive no power, I`ve placed a relay connected to the brown and green wire , the wires have power when the switch is turned on but when I check the number 9 wire on the 20 pins connector, I have no power. But, I HAVE a white plastic plain type connector not pluged (the one with 5 wires who share a black/white wire with the fuel pump relay) should I bypass some wires on this connector? And I dont have any EFI relay.
What should I do?? My harness come from a 81 automatic zxt.
Your help will be realy appreciate!
Thanks! :wink:
  • 4 weeks later...
Now I have power but no sparks, I can ear the click from the injectors, I receive a low fire signal from the y/w wire from the ecu but no sparks. I someone can help me?
