76 wiring harness and SDS
Guest mattz280
Guest mattz280
I'm getting ready to install an SDS F system soon.
I took a look at the wiring harness today. I followed it from the computer into the engine bay...it connected to the TPS, injectors, sensors, ignition system, AFM...ok no problem SDS replaces those directly. Then it runs around the front of the rad support and connects to the alternator, starter, battery and seemingly everything else. I'm not sure where every little wire connects to as it is all in a bundle of electrical tape.
So are there two separate harnesses on this car, or is it all connected. What do I have to disconnect from the harness and rewire when installing the SDS? Everything, or just a few components?
