Guest jjohart Posted October 12, 2003 Share Posted October 12, 2003 I JUST GOT AN 83 280ZX TURBO, AND I NOTICED THE CLUTCH SEEMS TO MAKE A VIBRATION WHEN I GO FROM 4TH TO 3RD GEAR, AND SOMETIMES ON LAUNCH IN FIRST. THE SELLER SAID HE'D NOT NOTICED CLUTCH PROBLEMS. IF I BLIP THE THROTTLE BETWEEN 4TH AND 3RD GEAR, I DON'T NOTICE THE SHUDDER. IS THIS A CLUTCH ISSUE (SLIPPAGE), OR SYCNCRHO. ALSO, I'M THINKING OF INTERCOOLING AND OTHER UPGRADES ON THIS CAR. IF I NEED A NEW CLUTCH, OR GEARS, AM I BETTER OFF WITH PERFORMANCE CLUTCH...WHAT DIFFERENT RATIO NUMBERS ARE BETTER IN GEARS 1-4 FOR BETTER PICK UP? Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted October 12, 2003 Share Posted October 12, 2003 might want to take a peek at this thread: http://www.hybridz.org/phpBB2/viewtopic.php?t=26375 may be some info in there to help Oh ya, and your CAPS LOCK is on Quote Link to comment Share on other sites More sharing options...
Guest freakypainter Posted October 17, 2003 Share Posted October 17, 2003 clutch chatter is most commonly caused by imperfections on the surface of the flywheel. The flywheel is much like a brake rotor, it will warp , distort and heat crack, all of which result in a vibration while engaging, much like your brakes vibrate while stopping when the rotors are warped. The solution is to have the flywheel resurfaced and install a new clutch. Quote Link to comment Share on other sites More sharing options...
