info needed
Guest Lsb4life
Guest Nic-Rebel450CA
If I am not mistaken, you cannot tub out IRS, I would assume that you have, or will be switching to a solid rear axle. If this is the case, all you really need to do is cut the inner wheel well close to the inside of the fender and leave a lip on it. Then you can make your new wheel well, or just move that piece inboard and take a sheet of metal to fill in the space between the well and the lip.
Here is a great pic from Mike kZ's page:
Great pic and great work!
