81 zxt coil in a 260 Z connections question
Im having problem to get sparks, I did the turbo swap from a 81 280zxt, the coil power resistor receive a signal from the ecu, I ear the injectors click (mean the dizzy is good) I have to use my 260 z wiring to get the power (late 260z) the 260z coil wiring have 4 wires : black/white, blue, black/blue and black/green. 3 wires goes to the ballast resistor (3 connections) and the blue go to the coil. The question is : How should I pluged these wires to get a spark , should I remove the ballast resistor and plug the wires directly to the coil? Do I need all these wires since Im using the ecu fire signal, probably not.. I need your help! This is the final step of a 2 years project, your help will be realy appreciate. :)
Thanks! :wink:
