After market steering column
Guest dbass
I am thinking about totally pulling the steering column and replacing it with a custom one with GM wire hook up. I plan on rewiring the entire car, and I can get rid of all old electrical wiring from the turn switch/light switch and ignition. I was thinkof one from flamingriver.com. Has anyone else done this, can it be done?
  • 2 months later...
Guest heinera
I thought about switching to a gm column to make wiring with a gm painless wiring harness more easy. But I didn't. And I am glad i did not. It would be a bunch of fabricating, and trail and error to get another column to fit. You know the stock column is just fine. It isn't hard to wire things up using the stock column and a universal painless kit. The only thing that I could not figure out was how to get the intermittent wipers to work. The only option that I have heard of is on and off.
good luck, Adam
