aero II guys inside !!!
Guest 400HP280z
Guest 400HP280z
i did a search and didn't see anything on how to mount the aero 2 front bumper. can someone please describe what you did to mount yours? pics of mounting points or brckets would be awesome too. i have a early 260 also and yes the turn signals are removed.
You need to remove the bumpers and bumper mounts. The the Aero front will bolt to the holes under the old bumper. The Aero front will need to be drilled to match those holes. Should be 2 bolts on each side, then one machine screw in the front inner wheel lip.
