Fuel Line Placement
Guest buschj
Guest buschj
I am installing a larger fuel line in my soon to be (350, 700r4, 73’ 240), what are the pro’s and cons of re-routing the fuel line away from the tunnel? Do I need all of the fuel tank vent lines, and a charcoal canister on a smog exempt car? Thanks in advance for your input.
I dont see any problem, you dont need a charcoal canister if the car is smog exempt (such as mine) i assume your going to run the lines along the frame rails?
I think that should be fine, in my experience the stock fuel lines flow plenty of enough fuel, maybe yours are partially blocked somewhere?
Dan
