silicone boy Posted November 9, 2003 Share Posted November 9, 2003 I have an open question for the forum. I recently picked up a TPI system as part of a twin turbo setup from EBay (paid just over a grand for a ton of stuff plus tons of extras in addition to what you see below) I'm not sure if I want to use the TPI, but then again, I kind of want to just because I've always thought they look great. I already have an Electromotive TEC3 setup with a 1000 cfm throttle body and a single plane intake manifold. As I said, the only reason I want to use the TPI is the way it looks. I've heard, however, that the stock TPI with 48 MM throttle body flows only about 700 cfm. Even with a bigger throttle body (added expense), I'd be hard pressed to get close to the 1000 cfm of the other system. Should I just bag the looks in favor of a little more CFM? Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted November 9, 2003 Share Posted November 9, 2003 You should also keep in mind the differences in performance. TBI and TPI act differently. TPI is going to give you greater responsiveness and a much more even flow and distribution. TBI has it's advantages too in that it produces pretty good bottom end, and I believe it can flow up in the higher RPMS better (this is why I am choosing to go TBI on my setup). Quote Link to comment Share on other sites More sharing options...
silicone boy Posted November 9, 2003 Author Share Posted November 9, 2003 I should clarify. My current setup is also a multiport system, just like TPI. It looks like this: It does have a throttle body, but it's not TBI. Quote Link to comment Share on other sites More sharing options...
