Guest Nic-Rebel450CA Posted November 17, 2003 Share Posted November 17, 2003 I do not know much about Vortec heads, and couldnt find much info about original configuration in searching. What type of intake are the vortec heads used with stock? I am thinking of using vortec heads with a TBI setup, so I would just need an intake that a carb could mount on. Is there any reduction in hood clearance typical from using vortec heads? Can vortec heads be used on Gen I engines? Can anyone indicate why vortec heads with a TBI setup would not be a great setup for high-rpm use? Quote Link to comment Share on other sites More sharing options...
Guest Z-rific Posted November 17, 2003 Share Posted November 17, 2003 You need a vortec specific intake to bolt up to an older SBC. Look on Edelbrock's website. I think they have at least 2. They also have dimension specs on each of their intakes. I believe they have a performer rpm intake for vortec heads. Quote Link to comment Share on other sites More sharing options...
Guest AJ78 Posted November 17, 2003 Share Posted November 17, 2003 http://thirdgen.org/techbb2/showthread.php?s=&threadid=41477&highlight=tbi+limited+horsepower+injectors+duty+cycle The concensus on thirdgen.org is that TBI is limited to 350hp at the crank with a 454 TBI unit. Unless your going with one of those 4bbl setups... I've looked at TBI quite a bit, you can do some neat stuff with the stock truck or f-body ecms if you run additional injector drivers. I've got 2 TBI units sitting in my garage that need an engine. Well, a car too. http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=2614&pid=9155 I'd start here: http://www.sdpc2000.com/cart.asp?action=catalog_start&catid=738 Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted November 17, 2003 Share Posted November 17, 2003 Ya, I plan to use a 4 bbl 4 injector setup. BTW, anyone know a good source for the 4bbl TBI units other than the Holley ($$) Commander? Did GM ever use a 4bbl setup in a stock application? Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted November 18, 2003 Share Posted November 18, 2003 Actually I guess the Holley Commander is a pretty good deal. I found a package for about $1200 and that includes the TBI, ECU, Fuel Pump, Sensors, Wiring, Filters etc. Quote Link to comment Share on other sites More sharing options...
Guest AJ78 Posted November 19, 2003 Share Posted November 19, 2003 GM never had a 4bbl TBI. You can find some bare units on ebay. Holley ECU's ugh... Check out the PROM section of thirdgen.org for some cool stuff. The main site http://www.diy-efi.org is down right now. Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted November 19, 2003 Share Posted November 19, 2003 Ya, I was thinking of getting the info from diy-efi.org, but the problem with that is that GM never made a 4bbl TBI, so there is no stock TBI that I can use in a diy-efi setup. Quote Link to comment Share on other sites More sharing options...
Guest AJ78 Posted November 19, 2003 Share Posted November 19, 2003 Ahhh... but there are driver boards you can get to drive the extra two injectors. It's DIY so if you aren't comfortable with soldering a board then I understand. I think I'm just biased because all the people on diy-efi constantly talk about how gm ecms are better than anything else. Quote Link to comment Share on other sites More sharing options...
