Guest polarity Posted August 1, 2002 Share Posted August 1, 2002 Well I'm working on buying that motor right now, should have it in a couple of days if all goes well. The tranny was already sold from this car (dang it) Can someone give me some more ideas of what things I am going to need. I know the MAF, ECU, wiring harness.. anything else I should try and get from this car. As I said in the earlier post it is a 93 camaro. Any input would be great. Thanks Billy Ronie Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 2, 2002 Share Posted August 2, 2002 I would buy the TPI/TBI swap manual from JTR. That has some good info in it for that kind of swap. You want to get everything from the donor car to make it all work. Davy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 4, 2002 Share Posted August 4, 2002 Originally posted by polarity:Can someone give me some more ideas of what things I am going to need. I know the MAF, ECU, wiring harness.. anything else I should try and get from this car. As I said in the earlier post it is a 93 camaro. The 93 motors are speed density, not mass air, so scratch that from your list. AS far as the harness, you could use the stock one if you're good with wiring, or get an aftermarket one through Painless, Ron Francis, Street&Performance, Howell...etc. If the car is an automatic, you're in luck because its a commonly available Th700r4, not the more expensive and troublesome 4l60E. Quote Link to comment Share on other sites More sharing options...
