Guest Anonymous Posted August 7, 2002 Share Posted August 7, 2002 Hi guys, Just thought I'd introduce myself. I'm Chris and I'm from Perth, Western Australia. I'm a mere 20yo, though have wanted to do a 250GTO replica ever since I saw a small magazine article about `em. Of course, it needs a power-plant, and what better than a 350 Chev? Well, a V12 would be better, but that'd be rather more difficult I'm a mad car & bike fan in general, and a big American sports fan. I'm a die-hard NHL (Dallas Stars) and NFL (SF 49ers) supporter, and a reasonable MLB (SF Giants) fan too. But that's another story.. Anyway, for my 350-powered 240Z/250GTO, here's what I'm going to plan on using if I can get my project underway: * stock 350 block * JE pistons (4.060" dome top) * Scat cast steel 400cid crank * Scat forged I-beam rods (6") * ARP bolts/studs * Hooker block-hugger headers * Edelbrock elite valve & air cleaner covers for that Ferrari look * Edelbrock Torker II manifold * Holley 700 or 750DP or similar (advice?) * Crane HI-6 ignition w/ PS-91 coil Not really sure what else. Can anyone recommend good brands for stuff like bearings, oil pumps, water pumps, timing gear, etc? Flywheel & clutch will hopefully be nice lightweight items. It'll run on 98RON unleaded petrol (gasoline to most of you), which is I think equivalent to 92MON. Redline will be a meagre 6500rpm, I'd like to see >300hp at the flywheel. Heads and cam.. I've got no idea, give me advice! Oh, I have no pollution laws to comply with, and I think the sound levels I have to be under is 95dB(a). Oh.. the gearbox will probably be a 5-speed Toyota Supra (regular or all-alloy, not sure yet). Hopefully some kind of LSD at the back, who knows what ratio! thanks guys, Chris Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 7, 2002 Share Posted August 7, 2002 Chris.. Welcome... Everyone has a different opinion on engines. Here is mine. Sounds like you plan to build a 383 stroker,I would go with a Edelbrock 750 CFM carb, Performer RPM manifold and a 234 degree Intake and 244 degree exhaust at .50 duration. Vortec heads. a balanced rotating assembly (pistons .rods , crank.flywheel and damper. Felpro gaskets and Clevite bearings. This should about bankrupt you. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 7, 2002 Share Posted August 7, 2002 Welcome to the forum! Your combo sounds good----all you need is money! Good luck! Davy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 7, 2002 Share Posted August 7, 2002 Tomahawk: Thanks for that. What would be a good place that has rough prices for that stuff online? summitracing.com or racesearch.com or something like that? I want to focus on low- and mid-range torque, rather than out and out horsepower. DavyZ: I've got to find a donor car first! I want to get the donor car sorted, then a stokc 350 Chev, then get the 250GTO bits, then start thinking of the bits I'd need for the engine.. Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted August 7, 2002 Share Posted August 7, 2002 Howdy Chris, What about using a stroked 308. I think they are close to the weight of the 302 ford and there is a lot of local info. Those that know say to keep the tourqe below 400 lb/ft for those supra boxes. Cheers Douglas Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 7, 2002 Share Posted August 7, 2002 Doug: Thanks for that.. it seems (over here at least) there's more info on 350s than 308s for some reason. What could I stroke a 308 to easily, anyway? I've no idea how much torque a motor like what I want will produce.. I guess if it's too much I'll have to use the all-alloy Supra boxes? I think they're rated quite high. Failing that, maybe a Tremec? They sound expensive.. I won't be driving particularly hard, or doing drag-racing or anything though.. Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted August 7, 2002 Share Posted August 7, 2002 Chris Have a look here http://www.comeracing.com/ I have a ali case behind my 350 chev. 400 lbs/ft of tourque Is a lot. I am shure they can take a lot more than that but thats what the bell housing guys say. Douglas Quote Link to comment Share on other sites More sharing options...
