Guest jjohart Posted December 2, 2003 Share Posted December 2, 2003 Hi, I've got an 83 280ZX in the shop for I/C install (Custom Tubes, Woburn, MA) and they find the large (tall) NPR intercooler off another owner's 280ZX is hard to fit in front of the stock air box. I have always been concerned with the possibility of water splashing into the open air filters, and am wondering if anyone has a suggestion..can the stock air box be cut, not to lunch box size, but anything to narrow it's width a bit? Anyone know of a shroud for so called "open air" filters that will protect a CFM a bit if it comes to doing that? Thanks John Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted December 2, 2003 Share Posted December 2, 2003 I say dont worry about the K&N filter... stock airbox is too restrictive. I posted an answer on your other post. If you're REALLY REALLY concerned, I say still swap to an open K&N then fab up a sheet metal 'shield' to go around it covering 3 or 4 sides... at least leave the top and maybe the front open... still way more airflow than a stock airbox. You can also get a thing called, I believe, a bypass valve. It mounts in the intake hose somewhere after the filter, not sure where exactly, but it's expressely designed to be a sort of safety net if water ever does find it's way into your intake. Quote Link to comment Share on other sites More sharing options...
