thumperZ Posted December 4, 2003 Share Posted December 4, 2003 I'm building a LS1 Z and i know that i can't use the mounts from JTR but what about the rest of the kit? can i use the rest of the kit for the swap? i've tried using the search but can't really find anything on this. i just got my engine/tranny and i need to get to work asap..your help is appreciated.. Quote Link to comment Share on other sites More sharing options...
fastzcars Posted December 4, 2003 Share Posted December 4, 2003 thumperz , try searching for a member here by the name of "Phantom" He had an ls1 installed by a garage. I think it was "john's Car's" or somthing like that? Out of texas. Give that a try. 8) Quote Link to comment Share on other sites More sharing options...
thumperZ Posted December 5, 2003 Author Share Posted December 5, 2003 thanks.. Quote Link to comment Share on other sites More sharing options...
innerware Posted December 5, 2003 Share Posted December 5, 2003 Email Mike Knell. He is the guy who wrote the book and he will be able to tell you for sure. His email is jags@tdl.com He is installing Ls1's into just about every thing else so he should be able to tell you Quote Link to comment Share on other sites More sharing options...
Guest 73TPIZ Posted December 5, 2003 Share Posted December 5, 2003 some good info here http://240z.jeromio.com/ Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted December 6, 2003 Share Posted December 6, 2003 ... but what about the rest of the kit?.. What else is there? The kit is basically just the engine and transmission mounts. Quote Link to comment Share on other sites More sharing options...
Guest gtmattz Posted December 7, 2003 Share Posted December 7, 2003 ... but what about the rest of the kit?.. What else is there? The kit is basically just the engine and transmission mounts. hood latch plate and radiator mounts come to mind.... Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted December 7, 2003 Share Posted December 7, 2003 Hood latch wouldnt be needed as you can use the stock one with an LS1 since there isnt a distributor in the back. Radiator mounts are only needed if you are changing the radiator. All of the pieces can be purchased individually from JTR as well. (If you find anything that you can use) Quote Link to comment Share on other sites More sharing options...
thumperZ Posted December 8, 2003 Author Share Posted December 8, 2003 sweet thanks for the info... Quote Link to comment Share on other sites More sharing options...
