Guest jjohart Posted December 18, 2003 Share Posted December 18, 2003 Hi, I was wondering if anyone knows what the size of the dashboard mounted speakers are on 280ZX or ZXT's, 79-83? I don't suppose anything larger would fit, would it? Quote Link to comment Share on other sites More sharing options...
innerware Posted December 18, 2003 Share Posted December 18, 2003 you can contact crutchfield.com they have all the answers Quote Link to comment Share on other sites More sharing options...
280Zen Posted December 18, 2003 Share Posted December 18, 2003 the speakers are 6" in the dash, If I remember correctly, I think there is room for larger speakers "oval" but you would have to drill new holes in the dash frame to screw down the speaker. Quote Link to comment Share on other sites More sharing options...
Guest ZmeFly Posted December 18, 2003 Share Posted December 18, 2003 More like 3.75 or somewhere close to there. One is easy to get to and its right above the glove box. The othere is a PITA to get to and take out. It can be done though. Quote Link to comment Share on other sites More sharing options...
Guest jjohart Posted December 18, 2003 Share Posted December 18, 2003 Yeah, 3.5 sounds about right...6 is the rear seat speakers (at least in my 2 + 2), I've already changed them out. My thinking is the rears sound so much better than the front that I ought to do something in the main field in front of me. I think doing component (tweeter and woofer) in the door panels is more promising than messing with the tiny dashboard speakers, especially with an outboard amp. Has anyone else done this? What size mid-bass/woofer did you use, I'm being told no more than 5 1/2 and that I'll lose my map pockets? Anyone done likewise? Quote Link to comment Share on other sites More sharing options...
Guest deedee Posted December 22, 2003 Share Posted December 22, 2003 The speakers are 3.5 or 4 inch speakers. You need to take the dash out to replace the speaker in the middle of the dash. The speakers are screwed on to the metal frame w/ a bracket. the only way you can get bigger speakers in the dash is take out the dash and to take out the little brackets that you screw into and move them to the size you want you need to use a welder and you have to be careful not to reck the dash inner frame. Good luck!!!!!!!!!!!!!!! DeeDee Quote Link to comment Share on other sites More sharing options...
Guest deedee Posted December 22, 2003 Share Posted December 22, 2003 The speakers are 3.5 or 4 inch speakers. You need to take the dash out to replace the speaker in the middle of the dash. The speakers are screwed on to the metal frame w/ a bracket. The only way you can get bigger speakers in the dash is take out the dash and to take out the little brackets that you screw into and move them to the size you want you need to use a welder and you have to be careful not to reck the dash inner frame. Good luck!!!!!!!!!!!!!!! DeeDee Quote Link to comment Share on other sites More sharing options...
