Guest Aguyandaredhead Posted January 4, 2004 Share Posted January 4, 2004 Ok I was in the garage and searching franticly for a piece of exhaust tubing that was just the right size to fit into the strut housings that I had just cut off and after having no luck the lightbulb came on. I have heard of many diffrent ways of aligning the two pieces and I dont think this has been mentioned but if it has DISREGARD IT..... OK use the piece of Angle Iron like described before but instead of using exhaust tubing use this http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=37353 And to boot I got it for 7.99 on sale.. Just drop it in and LIGHTLY expand it. Be sure not to weld it into the tube but that apply's to the tubing as well. Well it worked great and the two are perfectly in line. Now I cut mine so that the cut is under my threaded collar so it was only about 5 inches down but I suspect you could also use this further down the tub just use a ratchet and ext to tighten it. Well I hope this helps in someone's effort to complete this Mod.. Jeff Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted January 4, 2004 Share Posted January 4, 2004 Hey, not a bad idea at all !M! Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted January 4, 2004 Share Posted January 4, 2004 thats what i used on my front ones i did. i also used some L shaped metal strip and some Zip ties for extra holding power.. mike Quote Link to comment Share on other sites More sharing options...
Guest Aguyandaredhead Posted January 4, 2004 Share Posted January 4, 2004 great minds think alike.............. Quote Link to comment Share on other sites More sharing options...
