Guest j_string Posted January 27, 2004 Share Posted January 27, 2004 Hi guys new to the forum tryed the search function but didn't find anything. So the question is will an rb25det in it stock form fit in a 240z with the rb20 mount ? Or is there any modification needed to make it go down ? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Kelsey Mitchell Posted January 27, 2004 Share Posted January 27, 2004 Search is currently broken! From what i understand, you can do this but require a new intake manifold to clear the hood, but will use the same mounts! Quote Link to comment Share on other sites More sharing options...
baddriver Posted January 30, 2004 Share Posted January 30, 2004 Try the 6 cylinder board, there is a lot of discussion going on about the RB series engines there. I don't know much about the RB25DET, but from what I have been able to learn about the RB26DETT, it is a very expensive swap (compared to say, a V8) and requires quite a bit of custom hardware. The RB25 is a less expensive engine, so it'll cost less, but still may require quite a bit of fabrication. Quote Link to comment Share on other sites More sharing options...
