putting turbo on 240
pshepard327ci
this question is very out there but i have been wanting to make my 240z a little faster to help me deal with the fact that it will take couple more years for my v8 swap. I am curious on what i would all i would need to find to install a turbo on my z, and is it possible under say $1000, which is way more than id like but just to get some ideas. And if what parts i could snag from junkyards/online etc. i dont want a crazy setup just something even if it was a stock setup. any help would be great, thanks
peter
its a 1970 240 with 5 speed
There is a lot of info on this board,check Turbo forum,this question was asked before.Use search option. Also for $1000.00 you would be able to find 280zxt and swap engine in 240z.But there is more then just engine swap. If you want to do it right,you probably would need to update brakes/suspension/rear end. Use search on Zcar.com and Zhome.com.You will be surprise how much info you will be able to find.Good luck.
there is a guy on this forum who took everything above the block from a 280zx turbo engine and bolted on to his L24. you will also have to swap the wiring harness from the 280zx as well for the efi.
