660Z Posted February 5, 2004 Share Posted February 5, 2004 has anyone been able to remove a stuck r200 stub axle. I believe the snap ring is holding everything up. Mark Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted February 5, 2004 Share Posted February 5, 2004 Stub axle or input shaft? The stub axle has a nut holding it inside the strut housing and the input shaft is stuck into the differential with a snap ring. If it's the input shaft, then they do come out, just more force is required. Had just this on my new (old) differential. I wasn't able to remove it at the junkyard. I had to use a few prybars to remove it from the differential when I got home. For some reason, it was really stuck in there, but it did eventually come out. I really need to buy myself a slide hammer !M! Quote Link to comment Share on other sites More sharing options...
