deMideon Posted February 11, 2004 Share Posted February 11, 2004 If you are rebuilding it or building a stroker... it's very easy to get a new crank and have it internally balanced. I am building a 377ci (destroked 400) and that's what I did. Gives you a lot better choices. Quote Link to comment Share on other sites More sharing options...
Guest storm280z Posted February 11, 2004 Share Posted February 11, 2004 that 377 is goin to he a high reving monster Quote Link to comment Share on other sites More sharing options...
deMideon Posted February 11, 2004 Share Posted February 11, 2004 I am building it to top out at about 6500 max. I have learned from being on this board that I would have been better off doing a stroked 400 vs destroking. I really don't gain as much as I thought. But, it will still put out about 450hp in a reliable streetable engine! I was where you are at with the L28, I had 13:1 venolia pistons, polished ported head... etc etc... kinda fun to drive but just not real streetable or reliable. So that's why I am doing the sbc. Quote Link to comment Share on other sites More sharing options...
Guest storm280z Posted February 12, 2004 Share Posted February 12, 2004 demidion, what mods did you do to make 450hp an is that rwhp or is that at the fly? Quote Link to comment Share on other sites More sharing options...
deMideon Posted February 12, 2004 Share Posted February 12, 2004 It's the software HP I got from dyno 2000, so flywheel hp. Here's the setup! 400 block bored 40 over Scat 9000 crank, 400 mains, internally balanced, 3.5 stroke for 6" rods Scat 6" I beam rods w 7/16" bolts Keith Black 194 pistons 10.7:1 w/ 64 cc heads Canfield heads - 59.2 cc chambers Intake - 2.02 Exhaust - 1.60 head flow numbers: .1 - 63.5 .1 - 50.5 .2 - 130 .2 - 94 .3 - 185 .3 - 128 .4 - 237 .4 - 151 .5 - 252 .5 - 165 .6 - 253.5 .6 - 175 .65 - 255 .65 - 179 .7 - 256.5 .7 - 182 cam is CRANE 114681 (Thanks again Grumpy!!) Also have a vic jr port matched intake, an aluminum flywheel, and a 6 1/4" (I think) SFI approved balancer. I should have it in the car this spring, so we'll see what it really is! Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted February 12, 2004 Share Posted February 12, 2004 That sounds like a great motor you've built, D!!! Quote Link to comment Share on other sites More sharing options...
deMideon Posted February 12, 2004 Share Posted February 12, 2004 Thanks! Hopefully I'll have it together and in soon.... of course then I have to finish the electrical oh yeah I have to put all of the brake and fuel lines back in etc etc etc... ughh... Quote Link to comment Share on other sites More sharing options...
Guest Blazer406 Posted February 14, 2004 Share Posted February 14, 2004 im knocking on 11`s with a mostly stock 400 (12.2 @111 mph) with some tuning left. std. bore' date=' flattops, stock heads #882 , Lt1 cam (.460 lift), 1.6 rockerarms, 830 dp carb Mark[/quote'] Mine runs 6.41 @ 104 in the 1/8 with flat tops(pump gas), a hydraulic cam (.514/.524) and Motown 220cc heads(ported). Mark P.S. The motor is for sale! $3500. 6.40's in the 1/8th? ..... what does that translate to the quarter...... about 10.0 doesn't it? That is flying for a pump gas car...... you got any squeeze to get that? What kind of rear end setup are you using? What size rear tires? What gears? Please give us fellow z-car nuts all the details.... PLEASE Quote Link to comment Share on other sites More sharing options...
