Vented Rotors for a 240
Guest illbeda
Guest illbeda
I have a question concerning the upgrade to 84 vented rotors onto a 240Z.
Can you just swap the entire rotor and hub off the 84 onto the 240 spindle?Can you use the caliper off the 84 as well?has anyone out there tried it?
If not i need spacers,does anyone know who has these for cheap?
:bonk:
"Can you just swap the entire rotor and hub off the 84 onto the 240 spindle?Can you use the caliper off the 84 as well?has anyone out there tried it?"
Are you staying with 4lug? If so then you want to use your OEM hubs on your car with appropriate rotor spacers. This is for the 4x4 vented front setup/very well proven/a great moderately priced brake upgrade option.
http://www.modern-motorsports.com/catalog/product_info.php?products_id=48
"If not i need spacers,does anyone know who has these for cheap?"
Not sure what's cheap to you. They're listed in our package above. We only do top quality keeping value in mind, for my own ride I'd only want a piece properly made with no runout/perfect parallelism that was also perfectly hubcentric and concentric when it bolted up to my hub. I like happy mechanical systems when I'm doing my meant2fly imitations.
Drop me a private email if you have any specific package questions.
[/url]
