Guest scca Posted March 27, 2004 Share Posted March 27, 2004 oh and the actual mounts themselves are 1965 mustang -- these use a flat rubber bottom and a single stud so are easy to make a mount for as all you need is flat steel- there are 2 types of this mount - one uses a long bolt and runs thru it -- this is later 1966 early 66 and 1965 all use a stud in the mount instead of a bolt-- oh and steering is one additional u-joint and a heim mounted off the x-member to relocate it away for the oil filter and header clearance- the engine fits Very well and far back - but i still run a relocated oil filter for clearance-- Quote Link to comment Share on other sites More sharing options...
Guest Steve-Z Posted March 30, 2004 Share Posted March 30, 2004 I'm a new memeber and will be building up my car in the months to come. Ive ownd Z-cars since 1976 and still own a 1972 240Z Fairlady RHD and my 1972 240Z project car, which I would like to drive on the street and run events at places like Thunderhill and Button Willow. 1972 240 auto - soon to made mucho faster 1991 Ford 5.0 with T5 and a carb setup Short serpintine belt setup with a pass side alternator Alsil's front crossmember and some kind of trans crossmember Shorty headers with 2 1/2 in header pipes into 3 in exhaust pipe R-200 LSD with an unknown ratio Dan Oldenberg coil-overs with camber plates and Tokico 5-ways Larger stock front sway bar with a Dan Oldenberg rear sway bar Heim adjustable front and rear lower control arms 4 point bolt in roll bar - with future change to a real cage setup Some kind of sub-frame connectors Alum radiator with electric fan Some sort of road race type seat and five point harnesses Quote Link to comment Share on other sites More sharing options...
gwheeler Posted April 20, 2004 Share Posted April 20, 2004 1972 240Z' date=' with a 91 Mustang 5.0 HO, with EFI, and a T5. . . I haven't figured out exhaust yet. You can see the stock Mustang headers in the photos, but they're just sitting loosely so I don't fry my wiring harness when I fire it up. They don't exactly clear everything. I'm working on a clutch slave cylinder now. Then I have to get a drive shaft made. Then I have to do something about exhaust. After installing the radiator (280Z) and dual electric fans, it should be driveable, though I won't have any gauges.[/quote'] I've been busy. I got the clutch actuation figured out (Wilwood 1" MC with a Datsun truck slave), had a drive shaft made, installed the 280Z radiator and fans from an MR-2, installed a Crown Vic (normal rotation) water pump, very short serpentine belt (5 groove instead of 6, because the Crown Vic pulley had a different offset than the Mustang pulley), cut and rewelded the passenger side header to clear the frame rail, took it to an exhaust shop and had a 2.5inch 2 into 1 system fabricated (sounds good with a turbo muffler!), and I just put hood pins in (what a pain in the butt that was). Now it runs, drives, and seems reliable! It's the fastest car I've ever driven! What a laugh-riot! I find myself doing the evil laugh when accelerating out of corners. Today I ordered an air dam from Motorsport. When I get that the car goes to the paint shop. I want it deep glossy black with two white racing stripes. Next is all the gauges... anyone have a 280 tach? Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted May 13, 2004 Share Posted May 13, 2004 My 72 240 was purchased as a parts car. The car was basically stripped. I got another 76 for parts. My first brainstorm was to drop a 305 into it, but I picked up an 81 302/C-4 for 50 bucks. The body is pretty much rust free. It has fender flairs already installed and a sun/moon roof. The 280 gave me almost the whole interior, and brake system as the 240 didn't have any. I'm slowly getting the parts I need to put it on the road. I'll be running the R180 for right now, but want the R200. I also have to custom wire the whole thing, no big deal. The 280 gave me a tach along with a bunch of other stuff. So far I have about 300 bucks tied up into it. The 240 come with a set of wide 14" turbine wheels that I want to keep. I'm definatly going with side pipes. When watching the show called "Pimp my ride", I saw an tangeyello orange pearl paint on an 85 ranger I fell in love with. I think I'll have to get my wife a second job so I can get it on the road this summer. Quote Link to comment Share on other sites More sharing options...
Guest bobs302z Posted June 1, 2004 Share Posted June 1, 2004 carbed 302' date='268 extreme energy comp cam ,351 heads1" lowering suspension teck springs energy susp bushings autometer guages t5 steeda shifter cv half shafts mm adapters 1 1/2 , 225/45/17s ,federal tires line lock , rear 280zx disks, toyota front calipers [img']http://hybridz.org/nuke/modules.php?op=modload&name=coppermine&file=displayimage&album=2&pos=7[/img] having nothing but fun with my car!!!! Quote Link to comment Share on other sites More sharing options...
