Guest Anonymous Posted September 28, 2002 Share Posted September 28, 2002 i finally decided what engine setup tell me what you guys think SBC 350 stroked to 383 Eagle stroker kit 1 piece main seal rotating assembly Edelbrock aluminum heads 64cc Edelbrock 2x4 intake manifold Edelbrock performer carbs 2x with electric choke Edelbrock exhaust system Heddman street rod block huggers one question though what size tire do you think would go well with 3 inch flares i am thinking about 275mm? oh and for the transmission should i go T-56 or some thing else thnks again guys Quote Link to comment Share on other sites More sharing options...
DavyZ Posted September 28, 2002 Share Posted September 28, 2002 Is the double carb set-up for looks or for performance? If it is for looks and you have the cash, great, I completely understand. If, however, it is setup for performance, a large single carb will do just fine. Plus, you will probably save some money in the process. Do you know what RPM your engine will be able to turn? What are your cam specs? Just curious. If this is a racing engine with a forged & balanced rotating assembly able to spin upwards of 7000 rpm and a cam to match, well great, the double carbs will do just fine, otherwise a single carb would do the trick and be better for a street motor. Hopefully I'm right on track here, and some of the other guys will chime in. I'm not trying to dissuade you from building your motor, just throwing out some possibilities that may help you in the long run. Davy Quote Link to comment Share on other sites More sharing options...
