Guest jdllaugh Posted March 3, 2004 Share Posted March 3, 2004 What are the size and approximate length of the rubber fuel lines under the hood of a 280z. I'm going to look at a 75 280 for sale in a nearby town this weekend and the owner said the only problem is one of the rubber fuel lines in the engine compartment is leaking. Thought I might replace them and take it for a drive. Nice to know in advance what size/length of hose I will need. I've worked on a 240z, but never a 280. I assume the only rubber fuel lines under the hood are those that feed the injector rail. Feed and return, right? James Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted March 3, 2004 Share Posted March 3, 2004 I had a hose on the fuel rail split open on the way home after buying. I would recommend high-pressure for everything. Get about 4 feet to be safe. Maybe a few extra hose clamps, just in case. I replaced ALL the high pressure lines eventually, after a second split open and sprayed fuel EVERYWHERE. Good thing it wasn't on the exhaust side! Right: 6 injectors, fuel rail, feed & return lines. Quote Link to comment Share on other sites More sharing options...
