wiring?
hey friends, I am pulling the motor out of a 1974 olds cutlass, its a 350, but the only thing I am really worried about is if there are gonna be any unexpected problems with the wiring? I mean, not alot of wires, but will they work with my existing stock wire setup? I have a 1972 240z, any info would be much appreciated!
Guest greimann
If you have a wiring diagram for both vehicles, you should be able to match up system for system and be good to go. Like you said, there isn't much. Just don't use any ballast resistor into the HEI distributor.
