another ? Driveshaft?
a friend of a friend told me that you would have to get the driveshaft machined, wich to me makes since cause of the fact that the stock one off my z will be a little to long and the olds will be way to long! so is this true? how would I go about this?
Guest greimann
You will need to have a new drive shaft made. You can probably use the slip yolk and tube from your donor car. Visit your local driveshaft shop and they can tell you how to measure for the new one after your motor and trans are in their final position.
