Guest ON3GO Posted March 9, 2004 Share Posted March 9, 2004 not sure if this can help anybody or even if this is a waste of time.. but i was at school today and went on All-Data and got alot of info for our Z cars.. mostly for stock specs but some of this might help our members. It only went to 1982 so i got what they had. Alternator Bracket Bolt - 29-43 ft-lbs Alternator to adjustable bar bolt - 14-22lbs Compressor bracket bolt - 33-40lbs distributor support bolt - 2.9-5.9lbs Engine mounting brackets - 22-29lbs Gusset attaching bolt - 20-24lbs - M10 - 25-33lbs Manifold bolt & nut - M8 Bolt - 11-18lbs - M8 nut - 9-12lbs Oil Pressure sending unit - 7-12lbs Oil pump bolt - 8-11lbs Spark plug - 11-14lbs Thermostat housing - 9-14lbs Water inlet bolt - 7-12lbs Water pump bolt - M6 - 4.6-6.1lbs - M8 - 12-15lbs Water pump pulley stud- 4.3-7.2lbs Camshaft Locating plate bolt - 4.3-7.2lbs camshaft sprocket bolt - 94-108lbs Chain guide bolt - 4.3-7.2lbs chain tensioner bolt - 14-22lbs clutch cover bolt - 14-22lbs connectiong rod big end nut - 33-40lbs Crank pulley bolt - 101-116lbs Cylinder head bolt - 58-65lbs Cylinder head to front cover bolt - 5.8-10.1lbs driver plate bolt (A/T) - 94-108lbs Flywheel bolt (m/t) 94-108lbs Main bearing cap bolt - 33-40lbs oil pan bolt - 4.3-7.2lbs oil pan drain plug - 14-22lbs oil strainer bolt - 7-12lbs pivot bushing bolt - 58-87lbs pivot lock nuts - 36-43lbs rocker cover bolt - 7-12lbs oil pivot - 33-40lbs i have more i think, also please post if some are wrong.. i just wrote down what the system had. mike Quote Link to comment Share on other sites More sharing options...
